Wheel Bearing
Cobrarally
Wheel Bearing
Hi has anyone tried to change a front wheel bearing. mine seems to be siezed in any ideas or whats the secret?
jamesthomas404
Re: Wheel Bearing
im pretty sure front wheel bearings have to be pressed into the hub????
Re: Wheel Bearing
I think that you will find that a lot of hub bearings now get supplied complete with a new hub - as its cheaper when this work is done at the dealers.
