knocking noise!
ryandel
knocking noise!
Post by ryandel »
ive got knocking noise coming from the front of the car.
it only happens at low speeds even more when am coming up to a junction.
sounds as if something is swinging and hitting something?
any one got any ideas?
captainbeyond88
Re: knocking noise!
Post by captainbeyond88 »
this might sound silly but have u checked nothing is loose inside the hood?
whitegtipolo
Re: knocking noise!
Post by whitegtipolo »
come on mate how can we possibly diagnose that over the internet, take it into a garage ?? :roll:
ryandel
Re: knocking noise!
Post by ryandel »
whitegtipolo wrote:come on mate how can we possibly diagnose that over the internet, take it into a garage ?? :roll:
wow chill mate was only asking, cause i have already had it up at my uncles garage and we could see anything.
Re: knocking noise!
Right, I think that you might have TCA rear voided bush problems, I'm just guessing from what you have written! So, how to narrow this down a bit, if this is the problem, park on level ground with handbrake on and out of gear - grab each front wheel and try to move it forwards and backwards, if it moves "quite a bit" and you get a rubbery noise then one or both are damaged. Next, while driving, does this knocking make its presence felt while going on/off throttle? Also maybe when crossing kerbs and speed bumps? The other area you need to look at are the drop links (ARB to strut) - well known for wearing out at low mileage.
What age/miles engine have you got, also if you have TCA voided bush problems, then consider getting them replaced with the Ibiza Cupra solid bushes and you will not need to replace them again.
ryandel
Re: knocking noise!
Post by ryandel »
RUM4MO wrote:Right, I think that you might have TCA rear voided bush problems, I'm just guessing from what you have written! So, how to narrow this down a bit, if this is the problem, park on level ground with handbrake on and out of gear - grab each front wheel and try to move it forwards and backwards, if it moves "quite a bit" and you get a rubbery noise then one or both are damaged. Next, while driving, does this knocking make its presence felt while going on/off throttle? Also maybe when crossing kerbs and speed bumps? The other area you need to look at are the drop links (ARB to strut) - well known for wearing out at low mileage.
cheers man.will try what you said today.my car is an 08 plate 1.2 with fk highsport coilovers and droplinks and it has just under 11k
