vag-com
Re: vag-com
The ross-tech website. www.ross-tech.com
Re: vag-com
thanks alex.
Re: vag-com
is there any specific cable that i should order from ebay to run vagcom? also wich application of vagcom do i download?
Re: vag-com
ODB-II cable. VAG-COM 409.1 is the version you need
Re: vag-com
thanks again alex
Re: vag-com
which file do i download? the left or the right?
http://www.ross-tech.com/vag-com/download/archives.html
Re: vag-com
Right hand
Re: vag-com
thank you again
Re: vag-com
im having problems installing my vagcom. ivedonwloaded it of ross tech, and that went fine. However when i connected my cable, and tried to connect it to vag com it won't work.
Any suggestions? This is the cable i got http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
Re: vag-com
PM me tomorrow and ill guide you through making it work bud. Gotta configure the com ports and such
Re: vag-com
thought i would bump this rather then making a new one, i have problem with mine too, everytime i try to scan it just says cannot sync baud rate? any help?
Re: vag-com
whats vag com???
the machine to diagnose problems from your polo? are you lot downloading it to your computer and doing it from that though?
- Tim_GTi
- Post Whore
Re: vag-com
Vagcom is the software you run to communicate to the car's ECU. It can be run of most househouse laptops using an appropiate cable.adam_0612 wrote:whats vag com???
Re: vag-com
I know that newer VAG models can be programmed with vagcom (daytime running lights in US style, teardrop wiping yes/no, wiper intervals and so on).
What's the benefit if you have a 6N, apart from reading error codes?
