Mis-firing. Please help
kelly84
Post by kelly84 »
Hi guys,
My Polo GTI is mis -firing and i need some help identifying the problem.
I have change the HT Leads and the Spark Plugs twice but this has not worked.
It is off the road @ the mo and desperate to get her back on.
Any Ideas????
Kelly :cry:
Mike_M
Re: Mis-firing. Please help
Post by Mike_M »
Your coil pack.
I changed mine and it resolved the issue. GSF sell them at a cheaper price than VW and mine works perfectly
tegwin
Post by tegwin »
Have you checked for error codes in VAG-COM? A dodgy Cam position sensor could/might give a misfire!
Mr Rodriguez
Post by Mr Rodriguez »
more than sure its the coil pack mate, same has happened to my clio, the engine miss fires because the ignition system doesnt work as a unit. not an issue to be honest and can be brought and fitted cheaply. :D
kelly84
Post by kelly84 »
Thanks guys
A coil pack from GSF is £60 so will get one of them and see if that works. How much you reckon a garage will charge to fit it?
Kelly
Mike_M
Post by Mike_M »
There is a cheaper and identical one they sell.......same make etc etc for £36 as the guy found it on their system and said I could have that instead, which is what I got/paid 6 months ago.
Fitting is really easy.
Disconnect the battery and wait about 10min to discharge system, then unbolt the coil pack.
With the new coil pack near the old, transfer each lead plug to the same position (old to new).
Then bolt the new coil pack to the block where the old one was and check everything is secure.
Connect the battery and drive :D
30 to 40 min job
kelly84
Post by kelly84 »
Sounds like a job i could do myself which is good.
I will ask them if they can find the cheaper one on their system. Hopefully
Kelly
