iv had my valver a while now and it has always ran s**t since the cambelt snapped, it bent 6 valves but they have all been replaced and it didnt damage the pistons, since all this it has had various problems but the main problem i have had and still have is running problem it idles at 2 grand comes off choke and the revs go all over the place,ive replaced the throttle body reset it all changed the cts still have no codes coming up and suprise it still runs s**t, if anyone has any ideas i would be very gratefull because im clueless,
cheers dan
running problem HELP
Re: running problem HELP
had it back on the scanner it thinks the air intake temp is 90 degrees and the coolant temp is 19 degrees after running for half an hour obviously something very wrong going on there,as i said ive changed the cts soes any1 know if it common for the map sensor to go on these?
