[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Polo 9n Brake discs + pads - UK-POLOS.NET - THE VW Polo Forum
I recently purchased a 9n and i'm looking replacing the brake dics and pads.
Looking for something thats a little better than standard. (Even tho its a 1.2 )
256mm discs from what i have been reading
Thanks alot
Matt
Go for mintex discs and pads can't go wrong,plus up grade your flexipipes to braided and change the fluid to dot 5, this will make a big difference however as some have said already I would bit the bullet and up grade to gti spec as and when you can abit of work ie new hubs and removing the drive shafts to get the hub off but well worth it , I did it recently and the difference is big especially if you are used to the tea cup size discs.
