Number Plate
Number Plate
Does anyone know how to get to the light bulb that lights up the number plate, mine has blown
should be able to just open up the holder, cant reacll what it looks like!
but if its like any other in the VAG group then a CAREFUL use of a thin screwdriver will open up the catches, that are holding the covers in place should do the job and that will let you get at the bulbs......
well that's whats on my TT so I'm guessing it's roughly the same !
they are a frecking b***h to take out
i had to do both of mine
no troubling ripping the things out as i used a screw driver and when you lose your temper anything seems easy but they putting them back in again caused problems, they were all lose and stuff
but problem was solved with SUPER GLUE!!!
god knows how i am going to get them out again if they blow!
