i just bought hid kit
and am wondering what i should do for side lights any sugestions?
side lights
Re: side lights
blue side lights or xenon white LED side lights mate
Re: side lights
Thats if you can get the sidelight bulbs out.. Im having problems changing mine - grr!!.. pure nightmare, think the whole headlight has to come out to change them properly, unless you have tiny tiny hands. Someone please correct me if im wrong!
Re: side lights
i managed to get mine out fine and i dont think i have small hands!
just gota pinch the cables and juggle them slightly and tada done. well it worked for me n mine are fine!
get mtec XENON SUPER WHITE
http://www.hids-direct.co.uk/other-products.html (ones at the top)
Re: side lights
mate i understand what your sayin about gettin them out but if u can get a good grip on the plastic part that the bulb goes into give it a tug n it shud pop out mate
Re: side lights
I had the same problems too mate,made s**t of my hands
Iv found the best way is to grab the cables and pull hard,i was afraid of damaging connections but it worked out fine
Re: side lights
I can see where it should go (back of headlight cap removed) but do you really have to pull on the wires to get it out? Felt like I should twist it to release it but it only moves an eighth-turn...
Who'd have thought something so small could cause so much trouble? Don't answer that.
Re: side lights
bit tricky alright,confused me too when i was removing them!
Just give them a good old pull mate,takes quite a bit of force to get them out the first time!
