polo wipers/rear doorlock woes continue
greggo
Post by greggo »
Help a tale of polo problems
Having a nightmare few weeks with wifes polo 2002 diesel sdi 5 dr hback first rear nearside doorlock packed up got a spare from scrappie it wouldnt fit as the electrical connector on the relacement was an 8 pin connector on the broken lock it was a 6 pin connector so door is now held in place with a bungee strap !!!
Then all the wipers packed up i replaced the wiper stalk and indicator stalk which is a single unit steering wheel off etc etc etc pain of a job to do still no front wipers !! however the rear wiper worked - typical the one thats not essential !!! so I suspect the wiper relay is faulty sometimes it clicks sometimes it doesnt but im not sure which one is for the wiper I rang a vw spares place they said it would be relay number 99 but of course i dont have a relay numbered 99 does anyone know the wiper relay no for this car???
The part I need for the rear door is Y3B4839015AG with 6 pin connection if anyone has one lying around............
greggo
Re: polo wipers/rear doorlock woes continue
Post by greggo »
Had my head under the dash last night i think the odd click is coming from the relay numbered 18 but cannot be 100% sure allready bought parts i didnt need really need to get this relay number right any helpers ?/ is anyone out there ???????
Y3B4839015AG
Thats not a VW part number. The part number is in the format 6QX XXX XXX XX (for example) It always goes number letter in that format.
This is the part number you need 3B4 839 015 AG. FYI its over £90 new from VW!
greggo
Post by greggo »
AT that price I dont think Ill be getting it from vw !!!!!!!!!!!!!!! for your info that is the part number taken off the old lock as engraved on by good old VW when the car was made
greggo
Post by greggo »
All sorted now second hand central electrics box from scrappie £41 (vw wanted £354)
Doorlock £30 from geoparts online (vw wanted £115) a few hours to fit everything __ Back on the road !!!!
Re:
alexperkins wrote:Y3B4839015AG Thats not a VW part number. The part number is in the format 6QX XXX XXX XX (for example) It always goes number letter in that format.
Absolutely, that is the thing about VAG, you can normaly guess the part number as they use a very structured method, probably that is due to the British army restarting them after WW2!
To the OP, good to hear that you sorted it though!
