Not Starting
- chrischap2003
Not Starting
My Gti, seems to not want to start if i have driven it and then get out for a short time and when i get back in to start her she just wont start... it really seems like its the immobilisier, but its strange that most of the time it starts with no bother and its only when ive left it for short periods of time :-s
Anyone else had a similar problem? Or any remedies?
Re: Not Starting
it sounds like the temperature sensor is at fault
- chrischap2003
Re: Not Starting
Genius.
How much are these? Do you have a part no. at all?
Re: Not Starting
GSF or Euro car parts do them, or you can go for the gen option. They are about 10 quid thereabouts, a little more if genuine, but they are all the same
- chrischap2003
Re: Not Starting
Your a life saver Alex, appreciate it... i was gettin to the point where i felt like burning her out and claiming haha!
- chrischap2003
Re: Not Starting
Well the stealers kept ther name up, just over £30 for the Temp sensor. Any ideas which one i require off GSF or Euro parts, thers a few available
Re: Not Starting
Thats not one I have heard before...
When I went into GSF they looked it up on the computer and right away knew it was the little green thing with the four pin connector bla bla...... They need to look again if they think there is more than one
If you car is still messing you about... you can actually unplug the temp sender... the ECU will insert a "safe" average value into the fueling calculations and the car should run reasonably well without it plugged in! Better that than have the ECU think its 50 degrees C or something silly!
- chrischap2003
Re: Not Starting
I ordered one from Euro Car Parts as it had a photo of the item so i knew it was the right one. GSF only had descriptions that really didnt match the item. Shame GSF seem loads cheaper lol
- chrischap2003
Re: Not Starting
Ok so its came today....Ordered it from Eurocarparts and its clearly a used item...i could have had a new one from the dealers for £5 more (i only ordered it from ECP because the closest dealer is 30 mile away)
Anyone dealt with Euro Car Parts before and had similar problem?
Re: Not Starting
take it back i got a genuine part from vw as mine was having the same problem, as vw for a trade price they normally do it at mine for me
Re: Not Starting
used item christ thats bad! GSF it mate!
- chrischap2003
Re: Not Starting
I cant seem to find it on GSF though matey :-s
Re: Not Starting
Ring GSF up mate, they will have it, its a part that is used on a fair few engine codes of different cars
- Tim_GTi
- Post Whore
Re: Not Starting
never use websites for the likes of ecp, gsf and car parts alike. small details that get mixed up on the sites can waste so much time. always ring them. gsf will sort you out, all you'll need is your reg number. they'll deliver too.
- chrischap2003
Re: Not Starting
needed it done asap, cant live without my car. New item from dealer fitted and light has gone. genius haha... but no more dealing with EuroCar Parts i am afraid, found a canny local Volkswagen garage with discounted parts which ace
