As above...where did you route the power cable through the firewall? I know of a small grommet just below the glovebox, however on cars with AC, there's already something going through there which makes is tight. Allegedly, if you remove the wipers and scutle panel, there's another gromment which is used for the bonnet release cable on LHD cars...anyone used this? Or, is it safe to just make a small hole in the firewall with a drill? I'll be running a minimum of 4 gauge cable although may decide to run 2 gauge instead/in the future. Got a 4 x ~80 W RMS amp for for front components and might possibly add a ~200W RMS amp in the future for an 8" sub, so not really sure what cable to use...
Cheers,
Ash
