Engine spec help.
Veedub9n
Engine spec help.
Post by Veedub9n »
Is the 04 (65bhp) engine belt or chain driven??
Im pretty certain its chain, but when does it need replacing?? Some people hae said around 50k others have said a chain should never need replacing.
The car is due a service and its the 50k service. What will need changing??
Whos Adam?
Re: Engine spec help.
Post by Whos Adam? »
Which engine?
a chain should last longer than 50k,
That sounds about right for a belt
Veedub9n
Post by Veedub9n »
its 1.2 12v
Just that sometimes when you first start it up it makes a wierd noise. But not all the time. It could be starter motor or the chain (if it is chain).
K.I.T.T.
Drives: Bicycle
Post by K.I.T.T. »
All 1.2 engines are maintenence free chain driven.
Ash :)
Whos Adam?
As i thought!
no expensive cam belt change for us!
Just slow cars! WOO!
Veedub9n
Post by Veedub9n »
VW do an upgraded Cam Chain kit.
They would only have those if alot of people have had problem with them right??
If they slip/snap could be engine right off.
Just got me really thinking now the car has hit 50k.
Whos Adam?
Yeah I read its a common fault of them slipping,
Mine has just passed 60k and isn't as stable idling
ohhh wellll
Veedub9n
Post by Veedub9n »
Whos Adam? wrote:Yeah I read its a common fault of them slipping,
ohhh wellll
Whats it doing??
Mine stars at about 1.2kish and drops down to 800ish. But usually from a cold start.
Whos Adam?
Seems stable on start up, Idling just under 1000rpm
sometimes upon stopping it just dips down to 6-7000
nice old shudder and shes fine.
Cant be good though?!
