polo GTi? can-bus?
BIG4244
polo GTi? can-bus?
Post by BIG4244 »
Quick question realy, ive got a fault coming up which im thinking is preventing me starting, the car is a 6n but has full GTi ARC code engine, engine loom, interior loom, imobilizer, clocks, and E.C.U, the fault im getting is, power train data bus, missing message from instrument cluster? does it run can bus??? cheers
tomo87
Re: polo GTi? can-bus?
Post by tomo87 »
does what run can-bus? GTI's? i think that is correct...the reason that my rev counter will never work in my 20v
tegwin
Post by tegwin »
The 6N2 GTI does NOT run a canbus system...
The 9N GTI DOES run a canbus system....
Im not sure if ARC is from a 6n2 or a 9n....
But in the 6N2 the ECU HAS to be able to talk to the clocks AND the ignition switch/imobiliser transponder before it will allow the engine to fire.
If you are trying to run some weird combination of clocks etc that are not coded together, you may need to get the ECU unlocked... there are companies that can do that... remove all of the security stuff for you!
tomo87
Post by tomo87 »
ye thats what i meant hah cheers
jamie1.8tpologti
Post by jamie1.8tpologti »
tomo how come your rev counter dontwork???/ mine does
Tim_GTi
Post Whore
Post by Tim_GTi »
no rev counter? bummer :(
tomo87
Post by tomo87 »
i know, it works on the ibiza clocks....i can put one in but not too fussed as i know 2nd - 70mph, 3rd-100mph, 4th-120..
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
tomo87 wrote:i know, it works on the ibiza clocks....i can put one in but not too fussed as i know 2nd - 70mph, 3rd-100mph, 4th-120..
You have obviously tested this on a private road... :wink:
