Paint splashes on the bonnet, need Help!
Hey,
I have recently bought a 2002 red polo. It looks great apart from a few annoying little stone chips which i plan to get sorted and also on the bonnet of the car it seems to have loads of little dots of paint, im not sure of what kind of paint it is as it was already on there. But it looks like someone has painted something near it and the paint off the brush has splashed on to the car.
I have tried washing it a number of times and have also tried using a little T-Cut on it but havent been successful in any attempts of removing it
Does anyone have any suggestions in what could get it off?
Re: Paint splashes on the bonnet, need Help!
If you get some petrol, and dab it lightly with a cloth and lightly rub the dots of paint it should come off. Had do to it on my mates punto once cause it was vandalised with blue spray. Dont rub too hard though else it will rub away to the metal!
Matt.
Matt.
- Tim_GTi
- Post Whore
Petrol is quite risky. Have you tried just your fingernails?
If its white paint it could be off the white lines in the road and its a nightmare to get off, I had to take my last car to the body shop and get every splash sanded down and painted again.
Yeah i have tried with my finger nails and it didnt work, have also tried tar remover as i read somewhere that it can work but it didntTim_GTi wrote:Petrol is quite risky. Have you tried just your fingernails?
Is there anything other than petrol ? as petrol does sound abit risky
I dont think it is road markings as its just down the middle of the bonnet and not around the wheels or anything which i would have thought it would be if it was, but there again im not sure
wd40 ?????
havent tried wd 40. Will it not damage the car paint then ?
Cheers for the advise
WD40 wont damage the paint but doubt it will do anythin. Can try brake&clutch cleaner cuz that dont damage paint if ya dont fancy petrol
ahh right ok, ill try wd40 just in case it does work and if not ill see if i have some brake and clutch cleaner if i dont i will have to try petrol i spose what precautions should be taken ? the only thing im worried about is ruining the paint.gilbo-6n wrote:WD40 wont damage the paint but doubt it will do anythin. Can try brake&clutch cleaner cuz that dont damage paint if ya dont fancy petrol
DONT USE BRAKE / CLUTCH FLUID !!!!!
Is it risky then? Ill try Wd 40 anywaymwbpsx wrote: DONT USE BRAKE / CLUTCH FLUID !!!!!
a said brake and clutch CLEANER not fluid. Cleaner wont hurt ya paint but the brake fluid will ruin it.
Only prcaution is dont go mad else ya will end up rubbin the paint too hard and it will fade.
ahh ok if today is nice ill try wd40 and brake and clutch CLEANERgilbo-6n wrote:a said brake and clutch CLEANER not fluid. Cleaner wont hurt ya paint but the brake fluid will ruin it.
Thanks alot for advice by the way
No worries m8 Let us no how ya go on
hey tried wd 40.. didnt work how much is it for brake and clutch CLEANER ? I thought i had some but apparently i dont
