Going to be sad to see it go but then again you cant keep hold of everything for ever, the car is very well looked after, it recieves a full valet which i do at least once a month which includes full wash, polish and wax and full interior, i also try and give it a hand wash at least once a week and keep the wheels clean every other day quickly cleaned and rinsed !
There is no expense spared as you can see from the following and mostly genuine parducts are only used-
Details-
Volkswagen Polo Gti 1.6 16v
2000 x , 3door
Climate control
Electric sunroof
Electrc windows
75k with full service, half being VW
Taxed till March 2010
Mot till April 2010
Services & MOT's-
72,006miles Full service including Oil change, pollen filter.
72.006miles MOT.
64,108miles MOT.
61,981miles Full service including spark plugs, oil change, air filter, fuel filter, pollen filter, front disc and pads, rear pads, full cambelt kit, waterpump , antifreeze change.
55,038miles Full service including, oil change, air filter, spark plugs.
55,038miles MOT.
52,456miles All ABS sensors checked and connectors cleaned.
49,759miles HT leads changed.
48,049miles Full service including oil change.
48,049miles MOT.
41,718miles Full service including spark flugs, oil change.
41,718miles MOT.
Work which has been done-
74,003miles new passenger side electric window switch (genuine vw part)
71,355miles reverse light switch (genuine vw part)
68,762miles full coilover refurb (using genuine FK o-rings)
67,232miles temperature sensor (genuine vw part)
65,962miles gearbox refurb (ian thompson @ boston)
61,981miles water pump
61,981miles cambelt (using full kit)
55,713miles new clutch
36,703miles pedal box
Wheels & Suspension-
BBS RM splits, front 7.5" et 19 rear 8" et 12, stainless dish's (powerdcoated by mike the polisher)
Bright red vinyl squares on dish's
Toyo proxes t1r 195/45/15
FK kongisport coilovers
Engine-
B&M quick shift
Bmc cda induction kit
Pipercross oil breather
Exterior-
Drivers/passenger stubby mirror
Wolfsburg numberplate surround
Bosch areo wipers
B-pillars done in black vinyl
Genuine vw black front badge
De-badged & de-wipered rear tailgate
White led prism sidelights
Silvertech indicator bulbs (front indicators, side repeaters)
Oem+ sticker on windscreen
Wheel whores sticker on tailgate glass
Interior-
Kenwood cd player
Infintity door speakers
PRIVATE PLATE NOT INCLUDED IN THE SALE !
Loads of paper work and reciepts.
The car is located in skegness pe25, viewing is welcome but no time wasters or tyre kickers
£4450 ono
