Polo 16V Brake Set Up (6N2)
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
Ian_R
Post by Ian_R »
Here we have for sale the following - REMOVED FROM A 01 PLATE POLO (6n2)
16v Hubs
16v Calipers (LUCAS)
16v Caliper Carriers
Also Have Brand New Brake Flexi for both sides, also various new bolts etc. These will need new wheel bearings pressed in, so they will be like new. Also had these acid dipped and stripped of all the s**t that was on them.
There is some small places of surface rust, but easily removed - due to sitting for a while before i got them back. These are ripe for a brand new coat of paint!!
Please NOTE - reluctant to post due to weight of these, Although these will be in a box for pick up. If posted this will be at BUYERS Expense.
This would be a great upgrade to the standard Polo 8v brakes, as you also need the hubs off a 16v which are here, and then to upgrade to 280mm all you need is different calipers. Any Questions Please PM, i'm sure there is info i have forgot to put up.
PRICE = £150 ono
Just to add, i cant get net through the day, So Email - [email protected]
Ian
Ian_R
Re: Polo 16V Brake Set Up (6N2)
Post by Ian_R »
Bump
£130
