Polo 1.2 9N alarm led
akz786
Post by akz786 »
Hi guys just got a Polo 1.2 S 55BHP (9N1) now i am not sure if this car comes with an alarm? (would expect a standard VW immobiliser) - I got a standard key (not a flip key)
The issue I have is when I lock the car the red LED light on the door pin does not flash after even waiting for a few secs so im not sure if the alarm/immobiliser is going to be active....any help greatly appreciated!
dsw88
Re: Polo 1.2 9N alarm led
Post by dsw88 »
Check the fuses one for the alarm might be blown
akz786
Post by akz786 »
sure will do, any idea which fuse number this maybe or will that be obvious when i check?
dsw88
Post by dsw88 »
There should be a little card telling you what each one is for
Jollus
Post by Jollus »
I had that very same problem when i first bought the car. I bought a flip key with a unit off eBay for £50, bought a VW transponder chip to hold the immo code, had the blank blade cut and got it synced up with a laptop to start the car. (This gave me my manual key as a spare.) I noticed after fitting the unit and started to open the car with the remote, the red light began to flash on and off when it was locked. I think the way to tell if you have an alarm is if you have the little wired receptors in the top corners of your cabin inside the car. If you dont have those then the chances are you have an alarm for when the ignition is broken apart or a window is put through.
I dont understand though how my red light never worked untill I fitted the flip key remote control unit. Strange. Perhaps the unit completed a circuit for the red light to work or something.
JB_UK
Post by JB_UK »
may be obvious but when mine didnt work its cos i turned the key to lock it twice which turns of the alarm i think,
