URGENT! Lights have failed on my car!
MK6_Motorsport
Post by MK6_Motorsport »
Hi Guys,
Need some advice ASAP if possible please :)
My lights (main) failed when i was driving before and i don't know where the fuse box is.
Where are they located in a 9N?
Thanks in advance.
Dan
dsw88
Re: URGENT! Lights have failed on my car!
Post by dsw88 »
open the drivers door, as you look at the dashboard at the side theres a slot to put a screwdriver or something in, flick the panel off and the fuse box is there.
MK6_Motorsport
dsw88 wrote:open the drivers door, as you look at the dashboard at the side theres a slot to put a screwdriver or something in, flick the panel off and the fuse box is there.
Ahhhh ace, thanks a lot!
Do you know which fuse exactly is the one(s) i need to look at?
Thanks,
Dan
Whos Adam?
Post by Whos Adam? »
There should be a small white card in there with a diagram on! :D
