http://venommotorsport.com/product_deta ... y=Lighting
if so are they any good
anyone got these??
Re: anyone got these??
The replacement headlight clusters look okay, but it is the projector lens part of them that would interest me more as you could almost legally fit HID kits to them. Strange thing is that they do not mention this fact - a proper selling point I'd think. One thing though, they proudly make referance to being able to switch these lights between RHD and LHD, I'd think that this is them showing their lack of product use/knowledge in as much as the light pattern for LHD means that the dipped beam casts an extended corner of the beam onto the RHS of the road and the RHD dipped beam light pattern casts an extended beam on to the LHS of the road. Finally proper RHD dipped beam lights that can be adjusted or "switched" for use abroad only really flatten the beam and miss out this extended side ways cast portion that is meant to light up the kerb side - and I'd reckon that LHD versions will do the opposite. So, to sum up, I'd reckon that these light assemblies will all be "E" marked only for LHD use - so avoid until you have asked all these questions. Some place will just hope your slight ignorance is there for the grabbing!
