lock problem
SimonCorrigan
lock problem
Post by SimonCorrigan »
hi wondering if any one can help. got a problem with the central locking. the car locks except on the drivers side. i have tried using the key and the same problem that it won't lock. i can hear the mechanism moving but the door doesnt lock and the door pin stays up. any suggetsions?
Whos Adam?
Re: lock problem
Post by Whos Adam? »
Could be the cable which pulls the lock mechanism has come undone. There is a little hook on the end of a cable which pulls the lock closed.
If you take your door card off then you should be able to see if thats the problem.
It happened to me and I just had to squeeze the hook a little tighter with some pliers.
Hope its that simple :P
kingsleysaywell
Re: lock problem
Post by kingsleysaywell »
Abit off topic does anyone know where i can get a central locking part for the boot?
Whos Adam?
Re: lock problem
ebay, scrap yard or stealers :P
kingsleysaywell
Re: lock problem
what is it im looking for like the correct name? rough price?
Whos Adam?
Re: lock problem
if you go to dealers parts counter they will give you part name or google it
kingsleysaywell
Re: lock problem
ok thanks
