fusebox..... where isit??
where is the fusebox in a vw polo 6n2 gti?? stupid question but i cant find it?
Re: fusebox..... where isit??
Hey dude,if you sit in the drivers seat of the car and look right and down alittle in the small cubby hole (below the headlight switch) you'll notice alittle cover.Pull the tap towards yourself and the main bunch of fuses are behind there.Should be a card and small fuse remover tool in the lid.The card has small images next to the fuse number to help you see what is fusing what.Hope that helps.
Brad
Brad
