http://www.neobrothers.co.uk/fivespoke- ... p-363.html
would it be possible to get these wheels to fit a 9n polo year 2002?
also how do you go about changing the colour of wheels to be black? is this expensive?
cheers
saab wheels
david burton
Re: saab wheels
stud pattern is 5x110 I do believe
So you would need a custom made adaptor to get 5x100 to 5x110. Possible but expensive if no-one does them out of the box, and they will make the wheels stick out if the offset is low. Then the spraying would be about £50 per wheel at a normal place.
Probably more cost effective to find an aftermarket wheel that looks the same/similar and has 5x100 fitment.
Alternatively, you could fit a SAAB drivetrain
Mark_polo9n
Re: saab wheels
thanks for the quick reply.
so what is the 5x100 my 9n is then, i know the 5 is 5 studs what is the 100mm?
That covered everything cheers, guess i will start looking for some out of the box first. Anyone know any good places?
Aftermarket ones sound a lot cheaper than the saab ones but i do like the real thing, still as long as it look similar then im happy!
cheers
cheers
Re: saab wheels
your polo 9n is 5x100Mark_polo9n wrote:thanks for the quick reply.
Aftermarket ones sound a lot cheaper than the saab ones but i do like the real thing, still as long as it look similar then im happy!![]()
cheers
i'm not sure about saab wheel but from the above member saying saab wheels are 5x110 then these are the only off the shelf 5x110 H&R adaptors i can find they are vauxhall fitment
http://www.venommotorsport.com/product_ ... gory=Wheel
give venom a call with the spec of the bore size of the saab wheels and you should be sorted
Re: saab wheels
Fitting GM products to VAG cars -ouch!
Re: saab wheels
It's doable. They are 7x17. Likely ET41. Smallest adapters you can get are 15mm.
7x17 ET26 with 195/40 tyres would work on 9N.
It's a lot of trouble really (I've had 112->100 for Audi winters) for wheels that aren't wide enough to work out well.
If they were 8s then that might be better.
