hey im having some problem with me polo gti. it seems to be cutting out while idling and driving. its been fine during the winter during the cold but because of the hot weather now it seems to be doing it more and more.. i was wondering if anybody could tell wat the problem is?
thanks
car cutting out.
Re: car cutting out.
Get the car plugged into Vag-Com... See what error codes it shows up.... If you put your location in your profile someone local might offer to help!!?
may be relevant but had a similar problem. engine cut out randomly on more either idling or when driving. got vagcom said the camshaft and engine speed sensor werent working correctly. changed the crankshaft sensor which relates to the engine speed sensor and that ahs seemed to have fixed it. 2 weeks on hasnt done it once.
may be the same thing i know someone near me who had the same thing
