Seat wishbones
g__humm
Seat wishbones
Post by g__humm »
Do the wish bones off the cupra fit straight on?
yorks GT TDI
Sponsor
Re: Seat wishbones
Post by yorks GT TDI »
yes they do read my build for me gti has the part numbers for the in it
g__humm
Re: Seat wishbones
Post by g__humm »
Cheers do u know price
yorks GT TDI
Sponsor
Re: Seat wishbones
think the front wishbone bushs were about £9 each rear axle bushs were about £20 each
Re: Seat wishbones
g__humm wrote:Do the wish bones off the cupra fit straight on?
If you are asking "do the Cupra wishbone bushes fit?" - then yes, if you are asking "do the Cupra wishbones fit?" - then I'd think that they are slightly shorter to correct camber angle with lower suspension (it has been said), they will also have a cut out for the 6speed gear box that the lesser cars don't have.
I could be wrong but I'm guessing that you are trying to take the easy way out and just fit Cupra wishbones - priced about £80 each roughly, instead of just replacing the bushes with Cupra ones - I still reckon that the cheaper option is to get a good VAG indie to change the bushes and carry out a full four wheel re-alignment as you will need to get that re-alignment done if you change the wishbones yourself.
