body filling plastic bumper
greeny2515
Post by greeny2515 »
can u use normal body filler (for steal or fibre glass) on a plastic bumper, im wanting to take out all the bumper trim and filling it in. i was told by halfords it would just peel off when u try smooth it in then eventually fall off due to plastic moving about.
i had some problems wiv these guys before so want to know if its true or not. i know its been done but i dony kniw wot else to use, suggestions plz
g__humm
Re: body filling plastic bumper
Post by g__humm »
My painter suggests not to do it as it does crack eventully due to the expansion/contration and flex of the plastic he say you can get it plastic weld over tho this is better but more expensive I have seen the filler crack as well with stones hitting etc
greeny2515
thx mate, i done some research on the web amd found some plastic filler called upol, i think this should work, only one way to find out eh
Wooly_9n
Post by Wooly_9n »
I was speakin to my mate whos doing all my body work soon, a big suggestion is to prevent the cracking of normal filler, to plastic weld a strip in then smooth over the top.
He did however also say that carbonfiber type filler is ridiculously strong, useable on anything, maybe that could be another filler to thaink about?
