Hi guys,
my battery died the other day and after jump starting the car and since then my windows dont move by themselves. I have to hold the window switch up or down to move the window instead of just pushing or pressing it fully once for the windows to move automaticlly.
Any one got any ideas on how to fix it?
electric windows
Re: electric windows
Maybe a loose connection somewhere, or a fuse. I'd check the fuses first
- blazeguarder
Sounds like you need to reset the one-touch feature.
From Haynes: Switch the ignition on and off, then switch it on again. Close the window and continue to press the switch for approximately 3 seconds in order to complete the basic setting and activate the 'one-touch' function. Finally, switch off the ignition.
You might hear a relay click when holding the switch down, this means that it's worked.
i did the haynes suggestions and it worked,
thanks
thanks
