288mm Fabia vRS Calipers & Carriers - Fitment Options???
6N2 GTI 00
Post by 6N2 GTI 00 »
My mate has just uprated the brakes on his Fabia vRS from the standard 288mm to 312mm and he's now offering me his old brakes for a bargain price (calipers, carriers, Discs & Pads).
I know these can be fitted to a GTI but are they a fairly straight forward fit like the G60 upgrade or is there more work involved? I was planning on just the going for the G60 uprade but my mate is offering these too me at a great price and obviously the bigger the better 8)
Any help would be appreciated
Ben :)
Re: 288mm Fabia vRS Calipers & Carriers - Fitment Options???
There more work involved ben as as far as I am aware, they dont make a 288mm 4 stud brake disc. I think you would have to change to a 5 stud hub which starts to make things complicated
6N2 GTI 00
Very good point Alex, I cant believe I didnt realise that before. Feel like a right numpty now lol
Sounds like an expensive job changing the hubs over, I think i'll just stick to the G60 upgrade then to save some money
Cheers Alex :)
Bradley
Post by Bradley »
As mentioned i wouldn't bother with 16v 288mm discs.If you're after an upgrade go for G60 Discs and carriers,even then ive only ever noticed a slight difference if any.However a set with drilled and grooved discs ive been in a track pads was pretty impressive.
6N2 GTI 00
Bradley wrote:As mentioned i wouldn't bother with 16v 288mm discs.If you're after an upgrade go for G60 Discs and carriers,even then ive only ever noticed a slight difference if any.However a set with drilled and grooved discs ive been in a track pads was pretty impressive.
Good Stuff :D
I am hoping to get my brakes sorted next year, i'm still running just the 256's at the moment on EBC Drilled & Grooved Discs with Green Stuff pads
I did notice a big difference, but they aren't as good as they used to be. Perhaps a bleed is in order!
