Im fitting an amp in the front of my 6n, passenger side under the dash,
and was wondering where a suitable ground point would be?
i could easily wire my ground wire back through the firewall and use a ground point engine side,
but there must be a better place? using a shorter lenth of ground wire?
any advice would be much appreciated
thanks
Ground for amp in front
eddymcbrambram
Re: Ground for amp in front
also, is it possible to ?split? the remote turn on lead in any way?
so that i can run it to the amp in the front and an active sub in the rear?
just split the wire and run one to each
As for a ground, there should be one up inside on the inside of the chassis where the passenger wing would sit.
There are plenty of places around - if not, just put a decent bolt through part of the chassis under there
eddymcbrambram
cheers, i thought you could just split it, wanted to make sure though!
I'll have a look for the ground when i got a chance,
got all of next week off so im hoping to get it all wired up then
thanks again for the advice !
