Turbo bolts loose
Roms
Turbo bolts loose
Post by Roms »
Hi Guys,
Seem to have this problem again(turbo bolts loose) :x ....found out last yesterday while driving home - the car started to make a screeching sound when it starts to boost.
Would like to know if there is a permanent fix for this?
insamoufonyx
Re: Turbo bolts loose
Post by insamoufonyx »
this style washers, not sure where to buy though.
http://www.google.co.uk/images?um=1&hl= ... =&gs_rfai=
g__humm
Post by g__humm »
Could if you get desperate put retaining compond on from loctite we use it at work to hold bearings on a worn shaft and that works really well
