As the title..
Where is the automatic headlight adjuster thingy ma bob? I think mine's playing up and I want to take a looksie poo..
Is there only one?
Thanks!
Xenon headight auto adjuster
Re: Xenon headight auto adjuster
On the rear axle - if looking from the rear, its on the left hand side
There is often more than one - often one in passenger door too
Why do you think yours is playing up
I tried to adjust the beam using VAGCOM and no movement. Nothing, kaput!alexperkins wrote:On the rear axle - if looking from the rear, its on the left hand side
It kept throwing up a random error of the front left sensor.. That'll be the door one me thinks?
give us the error code
Also - the beam isnt adjusted with vagcom. That only controls the self levelling
If you want to change the beam angle and height, youll have to adjust it manually on the headlight itself
- nigelelliott394
Where does one adjust that on the actual headlight... because, umm.. well, fitting my sidelights, whilst trying to remove the cover of the headlight i started unscrewing at something that seemingly did nothing... when i realised this wasn't the screw i was looking for i just rescrewed it back but i fear i've now ruined the headlight alignment.
I feel a bit thick for doing that.
On the top. There are two holes in the firewall. One in the middle, and one on the wing side. They are white nylon, and require a large headed Phillips or 7mm Allen key to adjust
Middle does up and down. Outside does left to right
