Hid Ballasts
- Jay_6n2
- Drives: Polo Sel 1.6TDI
Hid Ballasts
Hi Guys,
Were have you mounted yours??
Any pics?
Jay
Any pics?
Jay
Re: Hid Ballasts
Depending on the size you go for:
Chunky ones are behind the bumper inbetween the arch liner and the bumper, or alternatively under the lip of the front where the bonnet catch is
slim ones can be mounted underneath the headlights as theres enough space in the recess
- Jay_6n2
Re: Hid Ballasts
slimline ones so guessing best underneath the headlightsalexperkins wrote:Depending on the size you go for:
Re: Hid Ballasts
Aye. Youll need to drill six small holes and use small cableties to mount them
Re: Hid Ballasts
any one got any pictures?
pleaseeeee?
pleaseeeee?
- J25LY
- Location: Birmingham : Drives: EP2 05 : Drove: MK5 1.4S
Re: Hid Ballasts
Jay,
which set did you go for in the end?
- Jay_6n2
Re: Hid Ballasts
went for these
http://www.rclick.co.uk/product_info.ph ... cts_id=814
in 6000k,
shall upload pics in a mo
in 6000k,
- J25LY
Re: Hid Ballasts
looking good mate! Is the car on standards or projectors?
any chance of discount off rsclick? btw where did you mount the ballasts in end?
Re: Hid Ballasts
If you want the discount, PM me with a request for it mate
Re: Hid Ballasts
you got any pics on where you mounted the ballasts mate?
Re: Hid Ballasts
also any idea if you need the bulb adapters?
and alex. whats legalities on these with no projectors?
Re: Hid Ballasts
Well, its still a grey area
The DoT Legislation states that if having xenon HIDs, you should have projection headlights, or headlights designed to take an HID bulb that are capable of displaying a clean and non-glary beam
However, there is no law that says its illegal, and MOT testers rarely will fail a test if a car has HIDs as long as the headlights are level and dont create too much glare
You wouldnt need any adapters - just make sure you get H7 fitment when they are ordered, or if you have a Mk4, you'll need to get a H4 Hi/Lo kit as the Mk4s have one bulb for both main and dipped beam.
You will get a better beam on a Mk4 also as its a patterned glass headlight, therefore itll have a crisper cutoff and less glare due to the design
Hope this helps!
Hope this helps!
- Jay_6n2
Re: Hid Ballasts
i ended up mounting the ballasts on the underside of the plastic cross panel at the top, reason for this as my hands were so cold and i had managed to cut my knuckle open, i may move them under the headlights when the weather picks up
Re: Hid Ballasts
yeah i got a mkv now. so this is definitely top of my list.
along with some rcl
along with some rcl
