Pretty cool?
tim
Pretty cool?
Post by tim »
jrw
Post by jrw »
Whats that then in English?
woter324
Cup holder blank?
Post by woter324 »
I believe this is where the cup holder is or should be if fitted. There is only one cup holder as the other side interferes with the steering wheel, however HOW DO YOU REMOVE THIS BLANK PLATE?
I've tried everything, even took the radio out and pushed from the back. It seems to be super glued in. Anyone had success removing this cover?
Scorpio1
Post by Scorpio1 »
I've done it loads of times... it shouldn't be glued in.
Get a VERY thin minus screw driver, take care not to scratch it or the dash, and prise it out very gently. If you haven't got a small enough screwdriver, DON'T do it!
