GTI Spoiler
GTI Spoiler
Regarding spoilers, what is to happen with the 3rd brake light? If the spoiler comes with one, what do you do about the factory installed light?
And if it does not come with one, surely the spoiler would cover it?
My car is a 1.4 8V Match.
Would I be able to simply get one from a breakers? Or would i have to buy a new one?
I've looked on eBay, but can only find 3rd party pieces of rubbish.
Lewis
Lewis
- nigelelliott394
Re: GTI Spoiler
I think to be honest, to properly fit the GTI spoiler you need a GTI tailgate to match. The standard tailgate doesn't have the holes to bolt the spoiler to and therefore requires lining up exactly and drilling your tailgate.
The GTI tailgate will allow you to have the spoiler fitted perfectly and no issues with the 3rd brake light.
Re: GTI Spoiler
OK,
If I want to buy one, how can I tell if it is a GTI tailgate?
Purely from the holes or spoiler attached?
Re: GTI Spoiler
Fitting a GTI spoiler requires some very very accurate drilling - I had to fit Greg's this summer and it was really fiddly to get the holes right first time. Granted I did measure it against a GTI tailgate, so the holes were easy to line up, but without that it wouldve been almost impossible
Re: GTI Spoiler
with the 3rd brake light lewis, what you simply do is pop the standard one out your boot and disconnect the wiring plug and that is the exact same plug for the 3rd brake light on the gti spoiler then the spoiler covers the hole of the standard brake light but then it's just aligning it up to drill the two bolt holes.
nick
nick
Re: GTI Spoiler
Oh, cool. Thanks.
I dont recon I'll be drilling my car any time soon. lol.
Thanks for the advice.
Lewis
Lewis
Re: GTI Spoiler
what? you dont need to drill any holes!!! mine fitted fine on my NON GTi boot lid, just make sure the spoiler your fitting has all the brackets, but i would recommend using some tiger seal on it really, as the seal on the spoiler isnt best!
Re: GTI Spoiler
i just bought one off ebay today as it goes. £45. so i dont need to drill? or is there 2 kinds of fittings? cheers
Re: GTI Spoiler
Theres two types. GTI ones and non GTI ones
GTI ones have two threaded rods (one each side) that are bolted through holes in the GTI tailgate.
Re: GTI Spoiler
mines most likely the gti fit one as its off a gti. i dont have any probs with the drilling. is there a rough guide anywhere? or any tips
Re: GTI Spoiler
I measured Gregs against another GTI tailgate with the spoiler removed to get the holes in the right place
If you dont get the holes in the right place and angle almost perfectly, it wont line up properly and it will sit funny
You may also need to buy the two special nuts from VW which hold the threaded parts in if you havent got those supplied.
Re: GTI Spoiler
I recently added a GTI spoiler to my wife's 6N2..
And I gotta agree with Alex, when I looked into it, if you want the perfect factory look - you need to source a proper GTI tailgate.
I got extremely lucky and found a complete GTI tailgate in satin silver (LB7Z) and got it a damn good price too. Most GTI's are Reflex silver so I did consider myself lucky!!
BEFORE
AFTER
BEFORE
AFTER
Re: GTI Spoiler
thanks for the info guys. the spoiler definitely finishes off the back of the polo beautifully. i should be spot on with the drilling being a metal fabricator. it does come with the bolts and nuts built into the spoiler.
i know the best way would be to get the tailgate. but its the painting etc thats gonna be a pain. iv'e yet to even spray the spoiler yet. as im working so much..
what black tape did you guys use thats seems watertight too?
would anyone suggest bonding this on without the screws? any info about. eg what to use
thanks.
update. spoiler just been primed. will give it a paint in a few days!
thanks.
