hi all after another set of coilovers this time kw's is there a major difference between the v1's and 2's? also being one of the most expensive will the ride quality be good some say similar to the standard car but obviously the performance?
thanks dan
kw v1's or v'2
Re: kw v1's or v'2
V 1 is ride hieght adjustment
v 2 is shock adjustment too
if you want lowness but still comfort ap are the best I have felt so far and I have been in a few not kw tho
if your build a track car the kw are for you
david burton
Re: kw v1's or v'2
I can recommend the V2s - had them on my Polo.
