This will be my 4th car, all of which have been of the VAG marque: Here is my car history and pictures of my 6R transformation. Please feel free to advise or critisize. Any feedback will be appreciated.
First car VW Lupo
[url
My 2nd car and by far most loved VW polo 9n
[url
And the car that I could not wait to get rid of. Seat Ibiza 2008 Reference Sport
[URL=http://img607.imageshack.us/i/4143 ... .png[/img]
The is my new car.
For suspension I fitted coilovers - Weitic Hicon GT
For wheels I fitted - Compomotive TH Mono 15x8
Tyre's are stretched Kumhos - 195/45/15
Tin plates were fitted and the vehicle is always cleaned with Autosmart products.
The coils
[URL=http://img404.imageshack.us/i/pict ... .jpg[/img]
The v8
[url
The insufficient clearance between the top nut and the skuttle panel cover meant I couldn't get my air gun in, so I had to remove the panel and my wipers
[url
[URL=http://img41.imageshack.us/i/pict0 ... .jpg[/img]
It's always handier working at the car when it's on 4 stands.
Macphearson suspension at the front and independant at the rear.
This is the spline socket required to take the bottom bolt out.
It's hammer time.
This is as far as the hub will come down on the drivers side of the car due to the driveshaft being stopped by the bottom arm. You could work your way around this by disconnecting the trackrod end, balljoint and driveshaft nut and removing the hub or just do what I like to do and compress the spring inside the shock and pry the hub down and get someone to hammer or lift the strut out of it's housing.
The back is always easy.
The ajusters must be placed in the nearest bin.
After everything was fitted, I gave the calipers, drums and discs a quick spray. Followed by de-mudflapping.
Just to clean and take a few snaps.
