Wireless Networks
Wireless Networks
This is a bit of a wird request, but does anyone know anything about wireless networks (peer-to-peer)? I want to set up a net work in a block of flats with one computer on the ground floor conected to broadband and at least three other computer on the first floor accessing it.
Shouldn't be a problem. You can pick up a new adsl modem with built in wireless (AP) and router for around £100. You'll also need wireless cards/adaptors on the other computers accessing the AP. Set-up is pretty striaght forward on a lot of the new hardware (with wizards etc guiding newbies).
Try: http://www.adslguide.org.uk for more info.
Don't be tempted by 802.11b (11mbps) because it's cheap - go for G band instead (54mbps). The few extra quid is worth it.
I got a 11b setup for that reason and it's only really useful for distributed broadband - it doesn't get near that supposed 11mbit/s for file transfers, more like 2 to 8 depending on the day of the week and what you send in which direction. Far quicker to burn a (4x) CDRW and walk between rooms! 11g however (54g?) should, naturally, be 5x that, and so comfortable for sending files between machines.
It looks complicated, but so long as you follow the instructions and are prepared to persevere a couple days it'll come together quite easily. Mine was little more than "plug together, follow the automated setup wizard, and slap the PC a few times"
I have a netgear too (813? erm, cant remember), its pretty solid apart from being sooo slowww
Oh and there's a little matter of it only opening TCP connections when you port-forward stuff through the firewall - UDP doesn't seem to work which isnt a problem in 99% of cases, but it means I can't use Direct Connect "properly"... (and the backup mode is a bit poor really). Maybe there's a firmware patch for it now, i'll have to check.
