Steering wheel rubbing problems?
Post by 5509433 »
My steering wheel has recently started rubbing/scratching/grinding when you turn the wheel.
I have looked around the wheel, and along the bottom left of the wheel, there is a small piece of what looks to be copper sticking out, rubbing on the wheel.
There is also, a square piece of metal moving about right next to it, Im not sure if this is normal..
This is hard for me to explain with out pictures. I can try and get pictures later tonight. Im assuming by removing the steering wheel i can try and fix the issues, but i don't want to remove the steering wheel to find out the shims or brackets (or what ever is beneath the wheel), is damages to hell so i cant put the wheel back on.
Has any one come across this problem before?
Lewis
Re: Steering wheel rubbing problems?
Thats the horn push ring. Squirt some WD40 in there and the noise will go away
Post by 5509433 »
Ok, thanks. I shall give it a spray tommorow.
Polo*
Post by Polo* »
yep same prob when i got mine. got some white grease in there. nice and silent now :D
