Hi All,
Im looking into refurbing my 6n2 steering wheel.
Can someone point me to a DIY guide on how to remove it?
Forum search didnt give me the right result, nor did Google!
Cheers,
PH-VAP
IS there a steering wheel removal guide?
Re: IS there a steering wheel removal guide?
take a look in the haynes manual if not its fair easy, on the back theres two holes you need to get a flat bladed screwdriver in there and flick the two clips up this removes the airbag unit. from there you just undo a massive nut to take the wheel off.
hard to put up a guide due to the nature of where the removal clips are on the back. haynes manual should help though i think. a worthy investment.
Thanks!
PH-VAP
PH-VAP
