Headlight restoration
TriggerFish
Location: Aylesbury, Bucks Drives: Polo GTi, 330d 'M-Sport'
Post by TriggerFish »
Hi all,
I've been on here for ages now, but never had to post before (credit to the site really!) and I've not done anything to the car, so no point it starting a build thread (should change over the summer once I've left uni though!).
Anyway, after reading a couple of threads on here about sanding down headlights I thought I'd look into it - and I achieved this: (shamelessly copied from Briskoda where I'm more active).
Ever since I’ve had my Polo I’ve been annoyed with the state of the headlamps. A lot of polishing has got them a bit better, but they’re still marked and pitted.
After having seen what people have been able to do with some sandpaper and time, I thought I’d give it ago.
I started off with 1500 grit paper, which after a while got the first light looking like this. While scarred badly, it was perfectly smooth now, so just had to get the transparency back.
Compared to before (left = sanded).
I then moved onto 2500 grit paper, which made no real difference visibly, and I forgot to take pictures. :oops:
After this I moved onto using some ‘rubbing compound’ from Halfords. I was sceptical a £6 could do so much, and was expecting to have a £200 bill from VW for a new headlight, but no, happily! If I were to do it again, I'd skip the 1500grit paper, but I guess that depends on the actual headlights.
Left = done.
I applied some polishes, titled ‘medium’, ‘fine’, ‘finest’ courtesy of BMW Mini, Cowley.
While not too obvious there, they’re soooooo much smoother, and all the scaring and pitting is gone. :)
And some of them back on the car after both sides are done:
Before/After
Not bad for the sake of ~£5 worth of stuff, and a few hours work! I'd happily recommend it to people with scarred headlights, although it does take a fair amount of time and tedious, repetitive, energetic arm movement. :devil: Just need to replace my passenger side headlight washer now, after it blew itself apart after I'd weakened it removing the cover. :roll:
Thanks for reading,
Joe.
Verity
Re: Headlight restoration
Post by Verity »
Good work! Looking much better now
Brilliant improvement. Deffinatly a job worth doing by the looks of it :)
6N2 GTI 00
Post by 6N2 GTI 00 »
Good work mate, certainly a decent improvement on how they were looking.
I need to do something similar to mine, I know Alex posted a good guide recently from a MK5 GTI forum.
neilw
Post by neilw »
Did this too mine. Its scary but worth it. Just take your time and go up through the grit levels. I finished off with Megs Plastex.
Godderz23
Post by Godderz23 »
Looks brillaint dude, well worth the effort. One of mine has started to haze slightly, will be looking into this in the near future.
