Jerky drive - error codes inside
S.Kayani
Post by S.Kayani »
Hello all, my polo gti has started to misbehave, its randomly jerking whilst in gear sometimes whilst drivin along, I got my mate to check the error codes, and this is what it gave back, any ideas on what I need to do to fix it?
VCDS-Lite Version: Release 1.0
Saturday, 09 April 2011, 19:04:38:0
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,41,45,46,55,56
Address 01: Engine       Labels: Redir Fail!
   Controller: 036 906 033 A
   Component: 1.6l/4V SIMOS3 00HS3259
   Coding: 00031
   Shop #: WSC 00788
1 Fault Found:
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
            P1103 - 35-00 - -
Readiness: 0010 1101
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 04001
   Shop #: WSC 00788
1 Fault Found:
00792 - A/C Pressure Switch (F129)
            35-00 - -
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 6Q0 909 601
   Component: 08 AIRBAG VW5       0004
   Coding: 12344
   Shop #: WSC 00788
1 Fault Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 55: Xenon Range       Labels: None
   Controller: 6N0 941 273
   Component: Leuchtweiteregelung X17
   Coding: 00002
   Shop #: WSC 00788
1 Fault Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
            16-00 - Signal Outside Specifications
End   --------------------------------------------------------------------------------------------------
Then we took it for a spin, and it came up with the missfire code
Saturday, 09 April 2011, 19:20:16:0
Control Module Part Number: 036 906 033 A
Component and/or Version: 1.6l/4V SIMOS3 00HS3259
Software Coding: 00031
Work Shop Code: WSC 00788
2 Faults Found:
P1103 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
S.Kayani
Re: Jerky drive - error codes inside
Post by S.Kayani »
Anyone know exactly what it could be? Think I need to change the temp sensor too? Because the temp gauge has been playing up since I got the car, although actually it seems to be working these days.
But the last time we scanned for errors it gave the following errors
Friday, 11 February 2011, 18:45:11:0
6 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
        P0116 - 35-10 - - - Intermittent
17927 - Shareware Version. To Decode all DTCs
        P1519 - 35-10 - Please Register/Activate - Intermittent
17511 - Shareware Version. To Decode all DTCs
        P1103 - 35-00 - Please Register/Activate
16684 - Random/Multiple Cylinder Misfire Detected
        P0300 - 35-10 - - - Intermittent
16688 - Shareware Version. To Decode all DTCs
        P0304 - 35-10 - Please Register/Activate - Intermittent
16556 - Shareware Version. To Decode all DTCs
        P0172 - 35-10 - Please Register/Activate - Intermittent
New temp gauge and check the spark plugs and HT leads
Also check the wiring for the precat lambda which is on the front of the manifold straight out the engine. The wiring on these often gets damaged, but it may also signify the that sensor needs replacing
S.Kayani
Post by S.Kayani »
alexperkins wrote:New temp gauge and check the spark plugs and HT leads
thanks for your help mate, my mate said that the lambda sensor was reading 0% so that must be faulty too, not sure where it is based tho?
also, any ideas if my cat could be causing these problems? brother mentioned he could smell rotten egg altho i havent really noticed it yet (not really been driving the car in this state)
The lambda is located literally where the exhaust manifold is on the right hand side. Look down into the engine bay at the front and youll see it bolted in
It could be the wiring as I say, so give it a good check
Your cat wouldnt be causing this. Im 99% sure of that
S.Kayani
Post by S.Kayani »
Cheers pal. I had a look at the lambda sensor. You were right, one of the wires was split so fixed that. Will check if it's still reading 0% on the laptop when my mate is free
Also changed the temp sensor an got mechanic to check the car, he inspected and changed the plugs, seems to have cured the problem (for now anyway)
All I need to do now is sort out the AC switch??
Ahh good glad to hear it :)
Should be ok now
As for your aircon...
Possible Symptoms
A/C System not working
Possible Causes
A/C System Malfunctions Over or insufficiently charged
Refrigerant System blockage
Insufficient Air Flow to Condensor and/or Engine Radiator
Wiring to/from A/C Pressure Switch (F129) faulty
Possible Solutions
Check A/C System for Malfunctions
Check Wiring to/from A/C Pressure Switch (F129)
Check A/C Pressure Switch (F129)
S.Kayani
Post by S.Kayani »
i might get kwik fit to check the A.C :)
car was fine for a couple of days, started becoming jerky again, think that means theres deffo summat up with 4 spark/ht lead? because all the mechanic did was clean them up
