Jerky drive - error codes inside
Posted: Sun Apr 10, 2011 11:20 pm
Hello all, my polo gti has started to misbehave, its randomly jerking whilst in gear sometimes whilst drivin along, I got my mate to check the error codes, and this is what it gave back, any ideas on what I need to do to fix it?
VCDS-Lite Version: Release 1.0
Saturday, 09 April 2011, 19:04:38:0
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,41,45,46,55,56
Address 01: Engine Labels: Redir Fail!
Controller: 036 906 033 A
Component: 1.6l/4V SIMOS3 00HS3259
Coding: 00031
Shop #: WSC 00788
1 Fault Found:
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-00 - -
Readiness: 0010 1101
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 04001
Shop #: WSC 00788
1 Fault Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 601
Component: 08 AIRBAG VW5 0004
Coding: 12344
Shop #: WSC 00788
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 55: Xenon Range Labels: None
Controller: 6N0 941 273
Component: Leuchtweiteregelung X17
Coding: 00002
Shop #: WSC 00788
1 Fault Found:
01538 - Motors for Headlight Range Adjustment (V48) / (V49)
16-00 - Signal Outside Specifications
End --------------------------------------------------------------------------------------------------
Then we took it for a spin, and it came up with the missfire code
Saturday, 09 April 2011, 19:20:16:0
Control Module Part Number: 036 906 033 A
Component and/or Version: 1.6l/4V SIMOS3 00HS3259
Software Coding: 00031
Work Shop Code: WSC 00788
2 Faults Found:
P1103 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
Coding: 00031
Shop #: WSC 00788
1 Fault Found:
P1103 - 35-00 - -
Coding: 04001
Shop #: WSC 00788
1 Fault Found:
35-00 - -
Coding: 12344
Shop #: WSC 00788
1 Fault Found:
Coding: 00002
Shop #: WSC 00788
1 Fault Found:
2 Faults Found:
P1103 - 35-00 - -
