bigger alloys
rasA4
bigger alloys
Post by rasA4 »
hi all whats the biggest alloys that will good without having to lower the car?
will be on a 1.4 SE car
cheers
west123
Re: bigger alloys
Post by west123 »
18inch on 215/35 haven't had any problems..no cracks or anything...
pics of my car
http://www.uk-polos.net/view ... =8&t=51219
rasA4
Re: bigger alloys
Post by rasA4 »
18" without lowering??
rasA4
Re: bigger alloys without lowering
Post by rasA4 »
was thinking either 15s or 16s only if wont look like a tractor
K.I.T.T.
Drives: Bicycle
Re: bigger alloys
Post by K.I.T.T. »
This is what mine looks like stock with the stock 15" Melbourne wheels
It's 15mm lower than standard due to being Sport trim, but gives you an idea of what 15 inchers look like. 15mm isn't that much.
Ash :)
blazeguarder
Re: bigger alloys
Post by blazeguarder »
Here's one of mine on 15" wheels and standard suspension. Anything more on standard suspension can look a bit like a tractor IMO. The 14" standard ones look a bit daft as well.
K.I.T.T.
Drives: Bicycle
Re: bigger alloys
Post by K.I.T.T. »
Oh snap (wheels) ;)
I think 15" is the way to go at normal ride height.
Ash
west123
Re: bigger alloys
Post by west123 »
Well I don’t think mine looks like a tractor :( and only the back can be lowered or the front will rub…35 tyres are so thin it looks as if the rubber is painted on :D …I did try a 40 tyre but that! did make it look like a tractor…all in all 18s are possible if they are good quality or the first pothole you hit will crack the rim
JamieG172
Re: bigger alloys
Post by JamieG172 »
Disagree, I think 16"s on standard suspension (not even the -15mm that Ash is running as is standard on "sport" models) looks good. Any bigger and u get into tractor territory.......
EDIT: By the way these are my 16" Monza's as found on the 9n3 GTI
K.I.T.T.
Drives: Bicycle
Re: bigger alloys
Post by K.I.T.T. »
16s don't look bad tbh at "stock" (ie, proper stock, not fake stock like some people :mrgreen: ) ride height. I think that's the first time I've seen a proper side on shot of one.
I think tyre profile also plays a role in this. I think my car looks deceptively lower than it is, probably due to 195 55 15 tyres that are on it. They're a tiny bit bigger than 205 45 16 and hence fill the arch up a bit more if you get what I mean.
Strangely, the sticker on the fuel cap says either 195 55 15 or 195 50 15 is acceptable, even though there's quite a bit of difference. Plan on trying the latter next...Uniroyal Rainsport 2 for £36 a corner :shock:
Ash :)
rasA4
Re: bigger alloys
Post by rasA4 »
thanks for your pics and thoughts guys! the Melbourne wheels look good, however the Montreals look better however they are 16s :(
JamieG172
Re: bigger alloys
Post by JamieG172 »
16" FTW !!! :P
Ps Mine are Monza, not Montreal/Montreal II.
rasA4
Re: bigger alloys
Post by rasA4 »
JamieG172 wrote:16" FTW !!! :P
Without lowering on a SE spec I'm sure will be a tractor
blazeguarder
Re: bigger alloys
I find that Monzas are a bit deceptive - because of their design they fill the arches well and therefore look pretty good regardless of drop. Jamie's car shows just how good they can be.
I personally think that alloys with more conventional spokes sometimes let a bit too much space show behind the wheel, which makes them look a bit lost unless they have a bit of a drop on them. VAG stuff is usually ok, but aftermarket wheels can look rubbish as 16" on standard springs. Since getting a 15mm drop on mine I've noticed how high the rear was on the standard suspension, even though the front doesn't show much of a difference. Put some masking tape around the tyre to mock up a 16" wheel on the car and have a look from a distance. Best way to tell what you think looks good without actually fitting any wheels.
Only my opinion of course, and I know that others disagree, but how boring would it be if we all agreed on everything lol.
K.I.T.T. wrote:Oh snap (wheels) ;)
Lol, excellent taste mate! Love the colour of yours as well...
rasA4
Re: bigger alloys
Post by rasA4 »
I won't be going aftermarket either VW or BBS these look good I think http://cgi.ebay.co.uk/polo-gti-bbs-whee ... _500wt_922
Looks like from an older shape polo
