selector shaft seal
selector shaft seal
I've ordered the gear selector shaft seal from Vw and going to be fitting it just asking for any advice on doing it?
Re: selector shaft seal
change it as quick as you can for one!
Ensure you undo the correct bolt to remove the linkage - its a pain in the ass to realign if you remove the wrong bolt
Youll need a sharp pointed hook to get the old one out, and a deep socket/pipe in order to push the new one in
Be interested to hear how you get on.
