needle sweep
needle sweep
anyone activated needle sweep on their gti yet this is a standard feature on the vrs which i guess should work on the polo
best demo ive found
*Do this at your own risk*
In Vag Com:
Address 17 – Instruments
Adaptation 10
Select “Staging” from the drop down list
Select “Active” from the drop down list
Save the changes
Done!
Now you might not see the cluster staging happen immediately after enabling it thru Vag Com…. You may need to key the car off & then open the door and then close it, and then key on the ignition again and then you should see it happen!
best demo ive found
In Vag Com:
Adaptation 10
Save the changes
Done!
- MODDED9N
- Location: Newbury, Berkshire Phone Number- 07949 330413
Re: needle sweep
Could I do this with VAGCOM on my 9n3?
- blazeguarder
Re: needle sweep
Don't think that this function is available on the 9N3. I haven't looked for it but there isn't any obvious way that I've noticed...
I don't know what to think of needle sweeps to be honest - I think it looks ace on videos but I actually did it once on an Audi and after about 2 starts I was finding it irritating. Personal preference I guess...
- Edi30
Re: needle sweep
Bit if a gimmick but yes personal preference.blazeguarder wrote:Don't think that this function is available on the 9N3. I haven't looked for it but there isn't any obvious way that I've noticed...
Re: needle sweep
That's the most pointless thing i've seen in a long time
- whitegtipolo
Re: needle sweep
Love it lol need to get me vag com
- whitegtipolo
Re: needle sweep
It says staging not available
darrenpolo
Re: needle sweep
Its a bit cheeky that they don't come with it as standard! I'd love the needle sweep
Re: needle sweep
any more info on this one? has anyone activated it yet? tried with my vag com today and once i selected staging in the drop down menu its just said it was not available? anyone know of a way round this problem? cheers for any help in advance
needle sweep
I guess it doesn't work then
Re: needle sweep
there must be a way its all over youtube will drop ross tech a email see what they say
Re: needle sweep
Any news from Ross tech on this dude. I tried it and as you say it just says not available.dobbo wrote:there must be a way its all over youtube will drop ross tech a email see what they say
needle sweep
I tried with 10.6.0 an had the same problem anyone tried 10.6.3/4 ?
Re: needle sweep
Mine is the current 10.6.4
Re: needle sweep
Sorry to resurrect a bit of a dead thread but did anyone hear back from ross tech regarding the needle sweep function. I've just checked with vcds 10.6.4 and with 11.8 beta and the staging function in instruments is not available
I'd like this feature and if I know it's impossible I'll have some sort of closure
