Change Brakes 9N...
Fannon
Change Brakes 9N...
Post by Fannon »
Would it be a hard job to do yourself on a 9N? Needing to change the discs and pads as the discs are warped and shake the steering when braking.
Its a 1.2 E 55BHP. Cheers
g__humm
Re: Change Brakes 9N...
Post by g__humm »
Don't see y it would be harder than any other car.
markallen
Post by markallen »
Yeah should be straight forward i suppose. Let me know how you get on as i need to do mine soon but ive got rear disc's too! :(
Might sound a bit corny, but if you need to ask then maybe you should buy a Haynes repair manual - and read through the relevant sections and then make your mind up.
