Ok So as promised here how to do it!
http://i720.photobucket.com/albums/ww20 ... needed.jpg
You will need, some pliers, a torx 15 bit, screw driver and some patients
http://i720.photobucket.com/albums/ww20 ... os/1-1.jpg
first take off the handbrake cover and lift upwards as seen below
http://i720.photobucket.com/albums/ww20 ... otos/2.jpg
once you have done this remove the rubber cover and unscrew the torx and remove any loose object, i.e ash tray.
http://i720.photobucket.com/albums/ww20 ... otos/3.jpg
http://i720.photobucket.com/albums/ww20 ... otos/4.jpg
http://i720.photobucket.com/albums/ww20 ... otos/5.jpg
once the torxs are unscrew lift the gear shift cover gently from the side and rear to lift it up. (careful not to lif to hard as it is connected to the cigarette lighter)
http://i720.photobucket.com/albums/ww20 ... otos/7.jpg
once this is done you can rest the centre on the hand brake for ease of work.
http://i720.photobucket.com/albums/ww20 ... otos/8.jpg
Now remove the 12v connection from the cigarette lighter (push in clip)
http://i720.photobucket.com/albums/ww20 ... otos/9.jpg
NOW FOR THE FUN PART! you may need to take a leap of faith, (or man up lol oj) and take pliers to the clip! carefully twist and turn it around making it snap! MAKE SURE YOU DONT BREAK ANY OF THE PRONGS HOLDING THE GEAR KNOB!!
http://i720.photobucket.com/albums/ww20 ... tos/10.jpg
http://i720.photobucket.com/albums/ww20 ... tos/11.jpg
the clip should look like the above. also make sure to keep the metal ring that comes off once the clip is taken off, (as shown below)
http://i720.photobucket.com/albums/ww20 ... os/122.jpg
once thats done you can now lift off the gear unit, shown below
http://i720.photobucket.com/albums/ww20 ... tos/12.jpg
push in the 4 white clips to release the gear gaiter and knob
http://i720.photobucket.com/albums/ww20 ... tos/13.jpg
http://i720.photobucket.com/albums/ww20 ... tos/14.jpg
after turn the gaiter inside out to expose the clearance clip, and carefully take the screwdriver and lift it upwards, there should be opening in the clip for seem of the gaiter so you can dig the screw driver from there as seen below
http://i720.photobucket.com/albums/ww20 ... tos/15.jpg
http://i720.photobucket.com/albums/ww20 ... tos/17.jpg
http://i720.photobucket.com/albums/ww20 ... tos/18.jpg
so now you can finally lift of the knob and replace it, if you also have a gaiter to replace then either remove the original gaiter or cover it over like i have.
http://i720.photobucket.com/albums/ww20 ... os/202.jpg
ensure the gaiter i over the gear knobs lip and turn over to adjust to what ever position you like.
http://i720.photobucket.com/albums/ww20 ... tos/21.jpg
http://i720.photobucket.com/albums/ww20 ... tos/22.jpg
put the clip back over the gaiter and lip, making sure that the clips male part fits into the knobs female part (SOUND ABIT WEIRD MYBAD!) you get the idea!
http://i720.photobucket.com/albums/ww20 ... tos/23.jpg
http://i720.photobucket.com/albums/ww20 ... tos/24.jpg
ok for this some people may have a clip already on the knob, thus needing a crimping tool, however i just resorted to a hose clip from home-based (does the same thing if not better and if you want to change gear knob again its easier) size i used was a 13mm to 20mm
http://i720.photobucket.com/albums/ww20 ... tos/25.jpg
you can now slide the gear knob back on making sure that it reaches all the way down towards he abrasive part of the shaft. once this is done ensure to put back the metal ring that was taken off earlier, attach the hose clip and tighten. (i positioned the clip towards the front so its out of the way and not noticed (its small enough to not be noticed anyway)
http://i720.photobucket.com/albums/ww20 ... tos/26.jpg
http://i720.photobucket.com/albums/ww20 ... tos/27.jpg
http://i720.photobucket.com/albums/ww20 ... tos/28.jpg
once this is done reverse your steps and put everything back together and enjoy, hope this helps
http://i720.photobucket.com/albums/ww20 ... tos/30.jpg
