Oil Filler Cap Gunge
k6chris
Post by k6chris »
I've just bought a Mk4 polo as a runaround and despite a very pleasing testdrive I am gradually discovering some issues! I have just opened up the filler cap and discovered it is coated with creamy brown coloured gunge (see picture if I can get it to post). I realise this is not good, but how bad is it and what is the likely cause?
Chris
k6chris
Re: Oil Filler Cap Gunge
Post by k6chris »
Just to add there appears to be no oil sprayed around the engine bay or rocker cover. The oil from the dipstick seems black and normal. I have not noticed any blue smoke etc and there is certainly no loss of power. The only sign of a potential problem is the gunge on the filler cap.
Chris
bessie67
Post by bessie67 »
is there any water loss or bubbles on dipstick if not all should be well i had this over the big freeze this winter just down to condensation if been standing awhile change oil +filter all should be well also short journeys do affect this hope this helps :)
Take it for a good drive on the motorway or similar. That should flush it through
