Wiring Diagram for 6n2 Comfort Flashers
As title states, anyone got a wiring diagram for comfort flashers / indicators on the 6n2 gti, as i've managed to cock mine up
- nigelelliott394
I shall be watching this thread closely
this is another mod I'd like to do
Re: Wiring Diagram for 6n2 Comfort Flashers
Should get a diagram with the MK3 kit mate.
Brown (31) > Brown (31)
Black/White (15) > Black/Grey (75a)
Green/White (49a) > Black/Yellow (49a)
Green (49R) > Black/Green
White (49L) > Black/White (L)
This may also be of some help to others.
http://forums.clublupo.co.uk/index.php?showtopic=64974
Excuse my stupidity but what are comfort flashers?
Running this small relay & pre wired loom allows you to flick your indicator either left or right and the indicators will flash 3 times with just a simple flick.Sometimes know as lane changing indicators dude,hope that makes sense.
Oh yeah, have that on the work van, it's really handy.
Right add that one to the list.
Either I'm retarded, or that wiring diagram is incorrect. For starters, I remember two of those wires not existing on the actual wiring loom, I had orange/white and something else. Someone may like to clarify this / slap me round the head. Gonna whip everything out tomorrow morning, and re-check my wiring..Bradley wrote:Should get a diagram with the MK3 kit mate.
Look what i won on ebay last night:
I will be watching this thread very closely
I'll let you know how I get on. Probably wont do it till tomorow though, weather's s**t and all.
Hope you manage to work it out easy enough mate
Didnt know if you could work it out from the wiring diagram posted on the clublupo, this one:
The wiring may be different but the number of pins on the hazard switch are gonna be the same so it looks like a case of just working out what colours are on which pins compared to the lupo.
Okey, the green/white wire from the comfort flasher loom is ment to pair up with a black/yellow wire on the hazard loom. Now, thats not available on the polo. The only two other unpaired wires are yellow/red and white/blue. Tried pairing to both, and no luck :s
The black and yellow wire should be on the new wiring and go to the green/white wire on the standard wiring, not the other way round.
Looking at your photo, you seem to have different VW coloured cabling for the Green wire and the white wire.
Once you have found them, it should work
Thats what I initially thought, but then I looked at the kit that you've bought, and the wire colours are all the same
Mart!n-GTI-DK has comfort flashers. by the sounds of it he did it a while ago. but might be worth PMing him, as he might remember exactly which wire goes where for the polo
