Removing gti steering wheel
Godderz23
Post by Godderz23 »
Going to attempt to change my steering wheel tomorrow, have read a few thread on removal. Disconnect battery, flat screwdriver etc...
Any of you guys done this?
Any hints/tips? Heard removing the clips on the airbag is a right struggle.
neilGTI
Re: Removing gti steering wheel
Post by neilGTI »
I didn't disconnect the battery when i did mine although for safe practice it is probably wise to.
The clips on the back of the steering wheel are a pig to get undone but as long as you have patience then you should get there in the end.
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Post by joe2612 »
Ok chris, disconnect battery first. Turn the wheel so one of the holes is at the bottom. Insert a medium flathead screwdriver,with the back of it as far against the steering collum and the flat bit as far into the right hand side of the hole with the flat bit vertical. (sounds abit complicated i know but i tried for hours to get it off and this is the method to use. Then lever the screwdrier outwards from the steering wheel...
Think i'll draw a diagram as its far too late for me to emphasise!
Godderz23
Post by Godderz23 »
Tried this evening for about 45 minutes with no joy. Got real mad and called it a draw. Will try again in a day or 2.
I get what you mean, I just cant seem to locate the springs, very weird.
Endi_GTI
Post by Endi_GTI »
Took me ages to get the knack as well mate. When you have done it you will kick yourself though :roll:
Remove the plastic cover under the steering wheel makes it alot easier
The clips are really easy to remove - do not insert the screwdriver all the way. poke around and youll feel the clip
you need to push the handle of the screwdriver up towards the underside of the steering column as high as you can so the tip is angled downwards
IE steering column side \ steering wheel where \ is the angle of the screwdriver
you then pull down gently and youll feel the clip just pop off
Should take less than 5 minutes to do.
joe2612
Post by joe2612 »
alexperkins wrote:Remove the plastic cover under the steering wheel makes it alot easier
A well elucidated version of what i was trying to say :lol: Don't just try any angle and don't force it, you may bend the clips back permanently and it my never come off!
Once i had the technique, the other clip was a breeze.
Why are you removing the wheel anyway Chris?
He's going for the no steering wheel look. Haven't you heard :mrgreen:
joe2612
Post by joe2612 »
alexperkins wrote:He's going for the no steering wheel look. Haven't you heard :mrgreen:
Lol, imagine explaining that to the police officer when he bins it :mrgreen:
Godderz23
Post by Godderz23 »
Progress update on removing the steering wheel. The old ones still on and the horn beeps when I turn corners.
More updates soon......
Lol mine did that for ages! Just the slip ring needs some grease on it
Godderz23
Post by Godderz23 »
It's off...!!!!
neilGTI
Post by neilGTI »
:D
You need to get a new scirocco wheel on there, they come off so easy compared to the polo gti wheel.
Godderz23
Post by Godderz23 »
neilGTI wrote::D
I wish mate. Saw the price of them on eBay, and no... :-(
joe2612
Post by joe2612 »
I am so tempted by them- i didnt think 280 delivered was That bad...
