Page 1 of 2
Removing gti steering wheel
Posted: Fri Jun 17, 2011 11:11 pm
by Godderz23
Going to attempt to change my steering wheel tomorrow, have read a few thread on removal. Disconnect battery, flat screwdriver etc...
Any of you guys done this?
Any hints/tips? Heard removing the clips on the airbag is a right struggle.
Re: Removing gti steering wheel
Posted: Sat Jun 18, 2011 8:56 am
by neilGTI
I didn't disconnect the battery when i did mine although for safe practice it is probably wise to.
The clips on the back of the steering wheel are a pig to get undone but as long as you have patience then you should get there in the end.
Posted: Mon Jun 20, 2011 12:58 am
by joe2612
Ok chris, disconnect battery first. Turn the wheel so one of the holes is at the bottom. Insert a medium flathead screwdriver,with the back of it as far against the steering collum and the flat bit as far into the right hand side of the hole with the flat bit vertical. (sounds abit complicated i know but i tried for hours to get it off and this is the method to use. Then lever the screwdrier outwards from the steering wheel...
Think i'll draw a diagram as its far too late for me to emphasise!
Posted: Mon Jun 20, 2011 9:39 pm
by Godderz23
Tried this evening for about 45 minutes with no joy. Got real mad and called it a draw. Will try again in a day or 2.
I get what you mean, I just cant seem to locate the springs, very weird.
Posted: Mon Jun 20, 2011 10:23 pm
by Endi_GTI
Took me ages to get the knack as well mate. When you have done it you will kick yourself though :roll:
Posted: Tue Jun 21, 2011 12:01 am
by alexperkins
Remove the plastic cover under the steering wheel makes it alot easier
The clips are really easy to remove - do not insert the screwdriver all the way. poke around and youll feel the clip
you need to push the handle of the screwdriver up towards the underside of the steering column as high as you can so the tip is angled downwards
IE steering column side \ steering wheel where \ is the angle of the screwdriver
you then pull down gently and youll feel the clip just pop off
Should take less than 5 minutes to do.
Posted: Tue Jun 21, 2011 10:00 am
by joe2612
alexperkins wrote:Remove the plastic cover under the steering wheel makes it alot easier
A well elucidated version of what i was trying to say :lol: Don't just try any angle and don't force it, you may bend the clips back permanently and it my never come off!
Once i had the technique, the other clip was a breeze.
Why are you removing the wheel anyway Chris?
Posted: Tue Jun 21, 2011 10:01 am
by alexperkins
He's going for the no steering wheel look. Haven't you heard :mrgreen:
Posted: Tue Jun 21, 2011 10:54 am
by joe2612
alexperkins wrote:He's going for the no steering wheel look. Haven't you heard :mrgreen:
Lol, imagine explaining that to the police officer when he bins it :mrgreen:
Posted: Tue Jun 21, 2011 4:08 pm
by Godderz23
Progress update on removing the steering wheel. The old ones still on and the horn beeps when I turn corners.
More updates soon......
Posted: Tue Jun 21, 2011 4:13 pm
by alexperkins
Lol mine did that for ages! Just the slip ring needs some grease on it
Posted: Thu Jun 23, 2011 9:36 pm
by Godderz23
It's off...!!!!
Posted: Fri Jun 24, 2011 7:39 am
by neilGTI
:D
You need to get a new scirocco wheel on there, they come off so easy compared to the polo gti wheel.
Posted: Fri Jun 24, 2011 7:44 am
by Godderz23
neilGTI wrote::D
I wish mate. Saw the price of them on eBay, and no... :-(
Posted: Sat Jun 25, 2011 11:12 am
by joe2612
I am so tempted by them- i didnt think 280 delivered was That bad...
